11-05-2008 08:40 AM
i use diadem 10.2, the german version, but sometimes the calculated channels are named the english way.
For Example if i use cclasssample with my diadem version the channels are named "VKlass_X" and so on
and with another german version the channel is named "CompoundClassificationX".
Where can i set these behavior?
Diademi
Solved! Go to Solution.
11-05-2008 09:09 AM
Hello diademi!
Select the menu 'Einstellungen' / 'Optionen' / 'Allgemeines...'. You get the dialog 'Allgemeine Einstellungen'. Click on the button 'Kompatibilität...'. In the dialog 'Kompatibilität' you have the flag 'Sprachunabhängige Ergebniskanalnamen in ANALYSIS' where you can set the behaviour. If you press Ctrl+A and paste in a text editor you can see that it is variable CompResChnNaming.
Matthias
| Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
