DIAdem
splitting up FileDlgFileName
Hello everyone... quick question here....
I have a list of *.TDMS files within FileDlgFileName, which I am then saving in a different directory as *.DAT files. My question is, how do I take the file name out of FileDlgFileName (ie, remove the path and extension).
thanks!!!!!
Tom
(4,615 Views)
Just to add to my question, here's some code... the problem I'm having is FileDlgFile is only the name of the last file out of the selection of files I want to convert.
Thanks 🙂
Tom
Option Explicit
Dim MyFileNames
Dim name
Dim iCount
Dim path
Dim J
Dim numberofchannels
Call DataDelAll
'name of files to use
Call FileNameGet("ANY", "FileRead", DataReadPath, "TDMS data (*.tdms),*.tdms", "All.lst", True, "Data selection")
MyFileNames = Split(FileDlgFileName,"|")
'MyFileNames2 = Split(FileDlgFileName
'path to save in
path = PathNameGet("Folder to save data in")
path=OutPutPath
For iCount = 0 To Ubound(MyFileNames)
  'open tdms
  Call MsgBoxDisp("loading TDMS file "& MyFileNames(iCount),"MB_NOBUTTON", "MsgTypeNote", 0, 0, 1)
  Call DataFileLoad(MyFileNames(iCount))
  Call MsgBoxCancel() 'close box
  'save as DAT
  Call MsgBoxDisp("saving CSV file" & path & FileDlgFile & ".CSV","MB_NOBUTTON", "MsgTypeNote", 0, 0, 1)
  Call DataFileSave(path & FileDlgFile & ".CSV","CSV")
 ' Call DataDelAll
(4,613 Views)
AHA!!!!!
ReturnValue = NameSplit(String, Type)
sorted 🙂
(4,609 Views)
Accepted by xxxtomxxx
Hello Tom,
to extract the name out of FileDlgFileName you can use the command
FileNameSplit(<FileDlgFileName>, "N")
Please refer to the help to get more information's.
Greetings
Walter
(4,607 Views)
