DIAdem
use variable in Chncalculate function in diadem
I need to use a variable in ChnCalculate function but takes only text so how do i embed the varaible in text inside that function. It keeps on beeping undefined variable where as i have already defined it at the start of program and also assigned value to it.
(4,948 Views)
Hello!
You can only use global variables allocated with the GlobalDim command or predefined global variables like R1 or T1 in ChnCalculate.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,946 Views)
It is still not working
here is my code
GlobalDim a
a = 10
Call ChnCalculate("Ch(""[1]/Clataca"")= (Ch(""[1]/Latac"")/Cos(Rad(a))-Tan(Rad(a)))")
(4,938 Views)
Accepted by GDU
Hi coolguru,
The syntax error is in your first line, it should be instead:
GlobaDim "a"
Brad Turpin
DIAdme Product Support Engineer
(4,933 Views)
Thanks Its working perfectly fine.
Solution Accepted
(4,906 Views)
