DIAdem
write diadem search results to text file
Is there a solution within DIAdem for exporting specific information from a search result into a text file? For example: I perform a search which returns all of the files, groups, and/or channels which I want to work with; now I would like to have, say, the file paths of all the results of my search exported to a text file. Is this possible? I could not find a direct way of doing this, but perhaps a script already exists for doing stuff like this?
(4,204 Views)
Hi mrclary,
I did not have this code handy, but I was able to whip it up for you.  Let me know if you have any questions.
Brad Turpin
(4,184 Views)
Thanks Brad, that works pretty good. Not that I'm complaining, but is there a way to call a dialog box for saving the text file? I tried looking through dialog box templates and didn't find anything.
(4,175 Views)
Hi Mrclary,
Sure, you can use the FileNameGet() function with the "FileWrite" paramter to prompt the user to select/define a new file path for you to use.
Brad Turpin
(4,138 Views)
Thanks, That worked great!
(4,109 Views)
