Over the years I find myself adding the following two requests to my modules more and more frequently:
The MHL code for these requests is very simple, and it doesn't get in the way for modules that don't interact with subpanels. I think these requests should be added to the standard singleton and cloneable templates.
I am familiar with the "create your own module template" argument against ideas like this. I've made those same arguments before. And I've implemented my own module templates with these requests before. But present-day, I equate the utility of these subpanel functions with the utility of existing core requests like 'Show Panel', 'Hide Panel', and 'Show Diagram'.
In addition to adding these requests to the core templates, we should also add a subpanel to the API Testers to (1) be able to test these requests (obviously), and (2) demonstrate the ease with which a DQMH module can be integrated into an existing subpanel-based UI.
Accepted for a future release.
We will mention the RTAllowDownloadSubPanels=True INI token in the documentation to fix the issue with LV Real Time
