My use case is simple :
I have a module that uses DAQmx functions, so the module's main VI will only be executable in DAQmx is installed.
Having a public VI from the module to check if the main.vi is executable is, I think, the fastest way for my app to report that a feature is not available due to missing driver.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
