Wouldn't it be great if double-clicking on certain failures in the Validator results window took us directly to the related place on the BD or the corresponding VI in the project window?
I'm thinking about the ones where you need to manually do something. Like disconnecting the Main VI terminals from its connector when moving from Run VI method to Start Async method, or updating your static VI ref by dragging the main VI onto the constant...
Available in DQMH 7.1
