DQMH Consortium Toolkits Feature Requests
psmorris
Enable reusing of reply payloads across multiple request and wait for reply events
Status: Declined
Too many implications.
Sometimes, I need to create two or more very similar request and wait for reply events - one to perform some kind of action (e.g. set the value of vertical range on a scope card) and one to query that value. In both cases I want to return the value that was actually set. At the moment, I end up with two identical reply payload typedefs as its not trivial to reuse them between events.
When creating a broadcast event you can already select to use the payload of a previously created request and wait for reply, I'd like to see that option available in request and wait for reply events too...
Paul
2 Comments
Olivier-JOURDAN
Active Participant
Status changed to: Declined
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
joerg.hampel
Active Participant
Hey Paul, thank you so much for your trust in DQMH, and for taking time out of your day to share your idea with us.
There will be issues when you remove an event tied to others with the argument or modify an argument tied to many events. We suggest creating the typedef or reusable argument ahead of time and use it in the argument window.
Again, thank you for your input, it is most appreciated. Please keep those ideas coming!
