DQMH Consortium Toolkits Feature Requests
psmorris
Shorten the label on the "Error" control in reply payload cluster
Status: Released
At the moment, when we create a request and wait for reply event, the reply payload (correctly) includes an error cluster to report any error that occurred during the handling of the request. However, the error cluster label includes the request name, even though it is within a typedef'd cluster which already uses the request name.
Not only is this a pain as it can take up a lot of block diagram space - I thought duplicating names of structures with a structure was not great style - if its in the "Do something request and wait for reply (Reply payload)" cluster, it probably doesnt need to be called the "Do something request and wait for reply_error"
Could it be changed to just be called "Error"?!
Just a thought...
Paul
1 Comment
Olivier-JOURDAN
Active Participant
Status changed to: Released
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
