DQMH Consortium Toolkits Feature Requests
TiTou
Event Arguments Window should use control values as default values for the public API request VI
Status: Declined
After consideration and discussion, we decided to decline this feature request.
We believe that our current implementation matches what the LV developer expects when wanting to make the control's default value: right-click> make default.
We really appreciate your input, declining the idea does not mean it didn't help us fine-tune the scope of DQMH and reconsider our strategy. Please keep those ideas coming 😉
When creating a new DQMH event, I'd like this
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
3 Comments
FabiolaDelaCueva
Active Participant
This is already implemented. The scripting tools directly copy the controls from the arguments window into the event arguments cluster.
You must "Make Current Value Default" when changing the values on the argument window and before creating the event.
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
TiTou
Trusted Enthusiast
as explained on discord, my suggestion is to not require the user to do the "Make Current Value Default" in the Event Arguments Window
Epictetus
Antoine Chalons
Olivier-JOURDAN
Active Participant
Status changed to: Declined
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
