All DQMH modules come with a Module Timeout--constant.vi:
This value defaults to 5 seconds, but I've worked with many modules over the years (usually having to do with serial devices) where this value is modified. I find it tedious to have to dig into the timeout VI any time I want to find out what the timeout actually is. Especially when I'm working with multiple modules at the same time that may have different (legitimate) timeout values. So I propose the following:
1) The default modules that ship with DQMH should include the timeout value in their icons:
2) There should be a Validate test that ensures the Timeout VI icon displays the correct value, and provide a fixer that will update the icon if it does not.
Darren, after reviewing your idea and discussing it internally, we decided to decline it.
We are declining this idea because we don't see a way to make it robust enough. There's a real chance that the actual value and the icon get out of sync, which would result in an even worse situation - the icon deceiving the reader.
Again, thank you for your input; it is most appreciated. Please keep those ideas coming!
