When developer use DQMH on RT, it is not possible to use the show diagram function. It could be painful when cloneable DQMH are used on RT target.
One solution to temporary debug the system is :
It could be great to add two tools :
We are not going to create the tool as requested, but we will look into ways to make RT debugging easier.
