DQMH Consortium Toolkits Feature Requests
Samuel_DAM
Simple Tools for helping RT debugging DQMH
Status: Declined
We don't think this should be part of the framework. This is currently a limitation of LabVIEW.
We advise you to submit an idea to the LabVIEW Idea Exchange. In the meantime, we will look into ways to make DQMH debugging on RT easier.
When developer use DQMH on RT, it is not possible to use the show diagram function. It could be painful when cloneable DQMH are used on RT target.
One solution to temporary  debug the system is :
  • Change the main DQMH VI in Non Reentrant execution
  • Change in the Reference management Vi the way we open the VI
It could be great to add two tools :
  • Temporally change this two option ( with message pop up to explain that it is only for debugging)
  • Add in the checklist on Validate DQMH, and add the possibility to go back
2 Comments
Olivier-JOURDAN
Active Participant
Status changed to: Development Started
We are not going to create the tool as requested, but we will look into ways to make RT debugging easier.
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
mbaudot
Active Participant
Status changed to: Declined
Matthias Baudot | Software Architect | Founder & Owner at STUDIO BODs | DQMH® Consortium Board Member & Trusted Advisor
STUDIO BODs     LabVIEW Champion     Certified Professional Instructor     DQMH Trusted Advisor     DQMH Consortium Board Member     GCentral Sponsor
 Check out my LabVIEW presentations and videos!
