DQMH Consortium Toolkits Feature Requests
AlexElb
place error handler in CDS
Status: Released
Solution: Place SEH inside a conditional disable structure with a symbol that users can add to their project if they want to disable it.
We are constantly having deployment errors on RT targets, mentioning the Simple Error Handler. Since on RT Targets that function is useless anyway, we've put a conditional disable structure around. This solved the error.
It would be nice, if that CDS would be added to a standard DQMH module.
Proud developer at Hampel Software Engineering where we turn '404 not found' into '200 OK'. Join us on Discord
2 Comments
Olivier-JOURDAN
Active Participant
Status changed to: Development Started
Hi @AlexElb,
Thank you for submitting the idea.
We get the problem, and we need to figure out how we want to fix it.
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
joerg.hampel
Active Participant
Status changed to: Released
