We are constantly having deployment errors on RT targets, mentioning the Simple Error Handler. Since on RT Targets that function is useless anyway, we've put a conditional disable structure around. This solved the error.
It would be nice, if that CDS would be added to a standard DQMH module.
Solution: Place SEH inside a conditional disable structure with a symbol that users can add to their project if they want to disable it.
