DQMH Consortium Toolkits Discussions
Benefits of using Broadcast over Global Variables
Maybe this is a very innocent question, but what would be the most benefits of using Broadcast instead of Global Variables, or Network-published variables (between PC and RT target)?
Thank you very much.
Pacino
(2,030 Views)
Accepted by Jinghang
Hi, this is a good question!
These are the benefits I can visualize right now
  • Minimize the risk of race conditions because the broadcast event is generated by the module itself and there can be as many listeners as you need, the global variable in contrast can be many writers and many readers.
  • Registration to a module broadcast assures you react to each broadcast update in contrast to a global, you can't be aware when the global is being written, in fact, you will need to use polling with the global.
Enrique
(2,028 Views)
