DQMH modules causes LabVIEW/TestStand to freeze for ~3 seconds
Seems that I was wrong about the number '4' (dunno why I've got that number in mind).
Here are important info about reentrancy : https://zone.ni.com/reference/en-XX/help/371361R-01/lvconcepts/reentrancy/
The table in that page summarizes well the caveats of shread reentrancy :
  • Determinism for multiple, simultaneous calling VIs : Possible waiting—Call sites may need to wait for LabVIEW to create a new clone if the pool of clones is empty. When the pool is not empty, pulling a clone and returning the clone to the pool can introduce non-deterministic delays.
  • Call overhead when no simultaneous calling VIs exist : Highest—LabVIEW must atomically pull clones from and return clones to the pool of clones. Calls may need to wait for LabVIEW to add a clone to the pool.
Really curious to know if you see any improvements when changing your test VI from Shared to Preallocate.
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
Message 11 of 13
(935 Views)
Tried to reproduce the issue and test out the re-entrancy settings. Of course, it wouldn't reproduce and the sub-sequence calls would all execute a VI call without locking up the software, so I couldn't test things out. I had already made fairly significant changes beforehand though, so I'm guessing something I changed has influenced the behaviour. As my workaround solution is in place and working, I have had to move on to meet project deadlines. If I get a chance, I will come back and re-visit this.
Message 12 of 13
(914 Views)
As I'm now confident this is not a DQMH issue, I've moved this issue over to the TestStand forum
Message 13 of 13
(882 Views)
