Project Root Not Empty?
I ventured into DQMH again today, and after installing it fresh into LV2024 64-bit, I opened Project Creation and it stopped me from progressing with the statement "The "Project Root" you specified is not empty. To create a new project, you must specify the path to an empty directory"
Why must the root be empty? I'm trying to create a new LV DQMH project in a Git working directory, which is by it's very nature not going to be empty. I have a .gitignore, and a git subfolder, and I actually have my own folder in there too.
Do I have to create into a temporary location, close LabVIEW, move all the files, then reopen? Is that a safe workaround?
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(679 Views)
Accepted by topic author Thoric
I think that's a reasonable workaround. Also note that this is a limitation for all project templates/sample projects, not just DQMH. The Create Project dialog requires that the destination folder for any new project be empty.
(674 Views)
Thank you, Darren. You can clearly see how much I use the project creation dialogue myself! I guess I'm still fairly old school in some ways 😉
(653 Views)
We (HSE) have never run into this problem because our repository structure dictates a subfolder /Source for the actual source code. So that is by definition an empty folder.
See https://dokuwiki.hampel-soft.com/code/common/repository-structure
(650 Views)
You might therefore find it ironic that the temporary folder I created became permanent and got renamed as "source" 😂
(630 Views)
