"Start Task" fails while using two task in parallel (DQMH CML)
Hello community,
since the acqusition is now working with my NI-9234 (in a NI-9185 chassis), I wanted to add a second card (NI-9215) and acquire signals as well (all with the DQMH CML Example Version 6.0).
In the Acquisition module, I changed the data cluster to have a second "DAQmx Task Name" (the first for my 9234, the second for my 9215).
But I do get an error, happening whithin the "Start Acquiring" case in the "Configure Hardware.vi":
Both my "DAQmx Start Task" fail with the following error message:
Error -50103 occurred at DAQmx Start Task.vi:7220002
Possible reason(s):
The specified resource is reserved. The operation could not be completed as specified.
Task Name: _unnamedTask<33>
I am not sure what I am doing wrong here, since I have those two "DAQmx Start Task" in parallel in other code as well. What am I missing?
Thank you.
Martin
(2,465 Views)
There are many possibilities, like having the resource reserved by NI MAX, or another module in your code. Can you attach your code here for a closer look?
(2,453 Views)
Yes, my apologies for not posting the whole thing in the first place. Here you go 🙂
(2,438 Views)
Is there any chance you aborted the code before the task was stopped? You can try going into MAX and hitting the "reset" button when you select your cDAQ chassis.
(2,430 Views)
I don't think that I aborted the task at any point.
It doesn't change anything after I reset the cDAQ chassis in MAX.
However, I do have some additional information. When I trie do run my acqusition I get these messages in the "CML Main.vi" message window:
37: Error code -200088 source: DAQmx Stop Task.vi:3590003<append> <DQMH>MHL Frame: Stop Acquiring</DQMH><DQMH>Event Handling Loop</DQMH> Additional Information: MHL Frame: Stop Acquiring
36: CML UI: Logger: Logging Stopped...
35: Error code -200088 source: Acquisition.lvlib:Acquire.vi<append> <DQMH>Helper Loop</DQMH><DQMH>Event Handling Loop</DQMH> Additional Information: Helper Loop
4: CML UI: Acquisition: Acquiring...
3: CML UI: Logger: File Initialized...
2: CML UI: Panel shown.
1: CML UI initialization succeeded.
Also I noticed that - when I press the STOP button within the CML UI Main - the aquisition stops BUT the STOP button is still active and the START button is grayed out.
Does this provide any useful information?
Thank you
(2,407 Views)
Accepted by mw42
Yes, it goes from most recent to oldest, so if you start reading from the bottom, you see the error starts at #5 in "Acquire.vi", with additional information to look in the helper loop. Now, I don't think there is any problem with the Acquire.vi, but take a look at how you wake up the helper loop, and see if anything needs to be changed now that you're using 2 DAQ tasks instead of 1 🙂
(2,400 Views)
Oh my goodness, HOW could I have missed that. It is so obvious. Of course I forgot to update my "Wake Up Helper Loop" with the second DAQ Task.
Thank you for pointing that out. 🤗
(2,392 Views)
