Digital I/O
6509 API
I have used the NI DAQ 6509 PCI card in my Dell Power Edge 860 server for years now, albeit with a PCI-X riser installed.
Works great.
I need to update my servers.
Possibly to the newer Dell Power Edge R230 which only has a riser with PCIe slots.
Therefore, I will need to replace my DAQ PCI-6509 card to the newer PCIe-6509.
Will I be able to use the same API calls in my code to detects signals with ths new PCI-6509e card?
API calls such as:
DAQmxCreateTask()
DAQmxCreateDIChan()
DAQmxStartTask()
DAQmxReadDigitalLines()
DAQmxStoptask
(4,771 Views)
Yes, it is still just using the DAQmx API.
(4,765 Views)
I have upgraded my development platform from Server 2003 to Server 2012.
Therefore I needed to uipdate my NI drivers.
I have downloaded and installed version 15.5 NI drivers on my Windows 7 64 michine as required by NI to support Server 2012.
I have converted a VB6 project using .NET framework 2 to VS2010 with .NET framework 3.5 .
My new VS2010 project references C:\windows\SYSWOW64\nidaqmx.tlb file producing a namespace for me called NIDAQmxCAPI which I import.
API calls such as:
DAQmxCreateTask()
DAQmxCreateDIChan()
DAQmxStartTask()
DAQmxStoptask
are no longer available to me.  Where can I find them?
(4,498 Views)
I wrote a VisualBasic app years ago in VS6/VB6 on a Server 2003 OS that communicated nicely with a PCI-6509 card.
I upgraded that machine to Server 2008 OS and installed v9.1 NI drivers and there were no issues communicating with the PCI-6509 card.
I now have a new machine with Server 2012 OS and installed v15.5 NI drivers as recommended.
The VS6/VB6 app has been upgraded to VS2010 using .NET Framework 3.5 and is running on the Server 2012 machine.
NI API calls were previously accessible via a VS6 reference to the C:\windows\SYSWOW64\nidaqmx.tlb  on my Server 2003/2008 machines.
The same API calls such as  DAQmxCreateTask() are not available to me using VS2010 and the same reference and the provided namespace.
Where can I find them if not where they used to be?
Are they not available on a Windows Server 2012 R2 64-bit machine when using VS2010 with .NET framework 3.5 ?
I tried switching the VS2010 solution's target Framework to 4.0 which I also have installed but it did not resolve the issue.
Anybody know where to find DAQmxCreateTask() in NI release 15.5?
(4,488 Views)
Accepted by willpfeiff
Found documentation I needed @ http://www.ni.com/example/6999/en/
That pointed me to DOT NET examples.
That pointed me to  ProgramFiles(X86) \ NationalInstruments \ MeasurementStudioVS2010 \ DOTNet \ Assemblies \ Curent \ NationalInstruments.DAQmx.dll
I added this dll as a reference into my VS2010 project
Then I had to set my VS2010 target framework to 4.0 which was reqiured by the new dll.
Now I have access to complimentary .NET calls to accomplish what I was doing in VS6/VB6
(4,462 Views)
