Digital I/O
9211 Installation Problem
I am having trouble communicating with the 9211 thermocouple device through the DAQ assistant.  It appears in the MAX as a USB device, but will not allow me to make a new virtual channel with it.  The device does works with the data logger, but I want to use this in a applicable VI.  Thanks for your help.
(3,727 Views)
Hi Jmc-
If you have a USB-9211 (with USB-9161 carrier) you will not be able to use the DAQ Assistant.  This device is supported only by NI-DAQmx Base, not NI-DAQmx.  You will need a USB-9211A (with USB-9162 carrier) in order to use the DAQ Assistant.
Hopefully this helps-
Tom W
(3,723 Views)
I have the NI cRIO-9211 with the NI USB-9161 carrier.   Is this compatible with the DAQ assistant?
(3,722 Views)
Hi Jmc-
No, the USB-9161 carrier and NI 9211 combination is referred to as a USB-9211 and is not supported by NI-DAQmx or the DAQ Assistant.  See my above post for more information.
If you would like to get started programming with NI-DAQmx Base for your device, check out the examples in \Program Files\National Instruments\LabVIEW 8.0\examples\daqmxbase\dynamic
Message Edited by Tom W [DE] on 06-20-2006 08:29 AM
Tom W
(3,720 Views)
