Digital I/O
Acquiring simultaneously with PCIe 6535
Accepted by CagnaccioCattivo
Carlo,
That code looks like it will do the trick.  While I don't forsee any damage that could be done routing your clock to the pin, I would take extra precaution to make sure it is connected to only the pin of interest and not touching a GND pin.  If it does, your signal won't make it through.  If you have a RTSI cable connector to use, that would probably be the best case for connecting to the board.
Kyle A.
Senior Applications Engineer
Message 11 of 11
(1,458 Views)
