Hi all,
I would like to choose DAQ board for my task. I have 4 DI. on every rising or falling edge of which I have to generate signal sequence at one of the DO and on every rising edge of this output signal I must read data on another digital input line. So I need a board with change detection (I choose NI 6509 ). But the problem is that this board does not support onboard timing. That means my output will be software dependent.
Which bard would be useful for my task?
Thank you for your answers, any help will be appreciated.
