Digital I/O
Change Output State if Connection is Lost
I am using a USB-6341 XSeries multifunction DAQ system to control an experiment involving a heated pipe.  I am using MATLAB to read a number of analog sensors, and the Digital Outputs to activate relays to control some heaters and a pressure relief valve.  My problem is that if I lose power, someone kicks a cable, or my computer crashes mid-test, I want the relays to turn off (ie return all the digital outputs to 0), for safety reasons.
I have figured out how to have the default output on power up be 0, but I havent come across anything describing how to do the same thing if a connection with the computer is lost.  Is there a property inside the DAQ that I can program to do something like this?
Jimmy
(5,609 Views)
you need to send some ack commands set by your self like PC send ack code and from DAQ you sent a counter value to PC, every time ack recieved , increment the counter and sent it PC. the ack and counter exchange interval should be set after every 1 sec or even less its upto you. make a check timer in your DAQ which check whether ack recived or not . if it is not recived for 1 sec means PC lost comm so THE check timer set you DAQ Digital IOs to boolean 0.
(5,603 Views)
Accepted by JimmyCrawford
The 6341 has a built-in watchdog timer for the digital I/O lines which is mentioned in the X Series User Manual in chapter 6 (pdf link).
You reset the watchdog timer from your software loop--if the timer expires the hardware goes into a pre-defined state.
I have no idea how it is configured in MATLAB, but in the C API the functions used are DAQmxCreateWatchdogTimerTask to create the task and DAQmxControlWatchdogTask to reset the timer.
Best Regards,
John Passiak
(5,592 Views)
