Digital I/O
Count edges of AI signal with NI 9221
I'm trying to count edges of an AI signal that are acquired with an NI-9221 on a cDAQ. The average frequency is about 1kHz.
I'm acquiring the signal with 10kHz but don't get the right amount of edges.
Is there any solution for this problem. I know, of course it would be easier to use a CTR-modul but my signals doesn't fit with the specs.
Thanks for any help
Yves
(4,102 Views)
Accepted by topic author Yves
Hi Yves,
there is a methode to count edged with a analog input. See link
http://digital.ni.com/public.nsf/allkb/B472ABA1362F44328625729C0041A8B1?OpenDocument
I hope this will help you.
Best regards
Sascha Egger
Sascha
(4,087 Views)
HI,
     I want to capture crank wheel singnal (which have max 100hz) through NI-9221 cRIO. i tried with NI examples but i
didn't get proper waveform.i called custumercare but i didn't get proper solution.Its urgent for me. please send me the
program. I attached both waveform(actual and waveform which get thruogh cRIO).
thank you
(3,682 Views)
