Thank you for contacting National Instruments.
As of NI-DAQmx 8.0, change detection is now possible with M Series DAQ devices! When used in conjunction with a timed loop, change detection can be used to respond to a hardware event (such as a transition on a digital line) in software. I recommend that you take a look at the "Event Response.vi" example in the NI Example Finder.
Michael P
