Digital I/O
How to do wired-or output in pattern i/o with the 6534?
For the 6534, there is no option in DIG_Grp_Config to set the output port into wired-or mode as there is for DIG_Prt_Config. How do I set the output port I am using for a DIG_Block_Out transfer into wired-or mode?
(3,363 Views)
Hi Jarvis,
Unfortunately, wired-or can only be used in an unstrobed operation (no pattern I/O). This means it can only be configured by the DIG_Prt_Config and not DIG_Block_Config. The following knowledge base and its links are helpful in understanding how it works with the 6534. Hope that helps clear things up.
What Is Tri-State and Which DAQ Devices Support It?
http://digital.ni.com/public.nsf/websearch/09B559BE292C75DB8625698500640E0A?OpenDocument
Ron
(3,363 Views)
Ron,
Thanks for the detail - where is this covered in the User Manual???
Jarvis
(3,363 Views)
Hi Jarvis,
It's not covered in the manual. I found it covered in one of the KBs I linked. I agree that it should be covered in the manual though. I'll put in a request to update this section. Thanks for your input. Have a good day.
Ron
(3,363 Views)
