Digital I/O
MAX 2.2 can not find Agilent E5810 gateway
I installed Agilent E5810 LAN/GPIB gateway and verified OK according to installation. However with NI-VISA 2.6 and related passport config, MAX 2.2 still can not see the gateway. Do you know why?
(3,731 Views)
The Agilent LAN/GPIB gateway will not show up in MAX. MAX only displays National Instruments devices. As long as you have installed it properly, and can talk to programmatically, you should be fine.
A.S.
Anu Saha
Academic Product Marketing Engineer
(3,731 Views)
My point is that Labview will not talk to the HP gateway if MAX can not see the gateway exist.
Does the solution in the doc 2Q2E1UPG solve my problem?
(3,731 Views)
Check out http://digital.ni.com/public.nsf/websearch/E56D3D4866BE0A8A86256942006626F0?OpenDocument
for more information on HP's GPIB boards working with LabVIEW.
Anu Saha
(3,731 Views)
I've the same problem, I've installed E5810 works with Agilent Visa but not with Max.
I've done all what's written in trouble shooting
(3,731 Views)
