06-07-2018
11:59 AM
- last edited on
09-20-2025
02:53 PM
by
Content Cleaner
I'm using PCI 6515 digital inputs to acquire a 64K quadrature encoder pulses attached to a motor with maximum speed of 3000 RPM. The encoder has two options of resolutions/revolution (32K or 64K). At this rate, with 3000 rpm speed - or 0.02 revolution/sec - the encoder produce pulses at 2.73 MHz (if 32K resolution is selected) or 5.46 MHz (if 64K resolution is selected). I looked in the datasheet and user manual of PCI 6515 (https://www.ni.com/docs/en-US/bundle/ni-651x-feature/resource/372172c.pdf) but I couldn't find whether PCI 6515 digital inputs can successfully acquire or detect the encoder pulses at this rate.
I really appreciate your help.
Thanks.
06-07-2018
12:31 PM
- last edited on
09-20-2025
02:53 PM
by
Content Cleaner
Very doubtful, by my reading of the specifications. The section labeled data transfers does not include DMA, only the much slower interrupts and programmed I/O. The manual referenced change detection but nothing about a timing engine.
Even if you could capture the digital signals, you'd still have to decode it into position information in software. It's much more practical to use a device with a counter that has built-in support for quadrature encoders. It'll be able to handle those signal speeds, and it will do the decoding in hardware, giving you incremental position measurements directly.
NI's X-series multifunction boards would be a good place to start looking.
-Kevin P
