Digital I/O
Missing first falling edge on DAQmx SampleClock
Hi there
i'm acquiring two ports on a PCI-6534 Board using external SampleClock on PFI3. The clock signal on PFI3 has a pattern like 0100 0100 0100....All works fine when i'm acquiring on the rising edge of PFI3 (8 Databits after 8 clocks), but when i switch to falling edge the first edge is not detected.
plz help...
thx in advance
i've atteched a simplified VI that shows this behaviour.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,682 Views)
did a little mistake: i'm using a PXI6534 instead of PCI6534.
Best regards
chris
(3,677 Views)
Hi Chris,
look at this to get an explanation of this behaviour.
http://digital.ni.com/public.nsf/websearch/2FB93421FAD8374286256BDF007A78AF?OpenDocument
best regards
Marco
(3,636 Views)
ah, ok.... that explains all.
didn't found that in the documentation.
best wishes and many thanks
chris
Best regards
chris
(3,623 Views)
