Digital I/O
Open drain for I2C communication using a PXIe-6341?
Hi all,
I am trying to set up a variant of I2C communication using a PXIe-6341 (and a SCB-6A). The Sensiron SHT-75 sensors use open collector (open drain) digital communication similar to I2C, but without multiple device addresses.
I want to communicate with 3 of these sensors. I plan to wire them up with a common clock and a separate digital line to the data pin for each sensor. Since it is recommended to provide them with 3.3V for calibration reasons (they will run on 5V) I was also thinking of using an analog output line for the power. Each sensor has a maximum current draw of 1 mA and the analog out is rated to 15 mA. I can use the 5V power line, but as I say, the manufacturer recommends 3.3 V.
The precise software I am planning on running is here: https://forums.ni.com/t5/LabVIEW/Sensirion-sht7x-labview/m-p/901063#M406440
I cannot find the specs anywhere on the type of DIO offered by the 6341. I have gone through the spec sheet with a fine toothed comb and found nothing. Am I looking in the wrong place? Why is this not a listed spec for the digital IO lines? How to I find out if this DIO hardware is open drain as opposed to push-pull (active drive)? I have the sneaking suspicion that I am missing something. . . ?
To sum up, can I carry out open drain communication to multiple SHT-75 sensors using a PXIe-6341? (And why is this not in the hardware specs?)
Thank you in advance for any assistance.
Message 1 of 8
(2,495 Views)
Accepted by topic author EamonnFPMcKernan
By default all DAQ device Digital Outputs are Push-Pull, hence only devices that support Open-Drain configuration will mention that it supports open drain.
You can implement open-drain communication by using an external tri-state buffer or a push-pull to open-drain conversion chip.
Santhosh
Soliton Technologies
Message 2 of 8
(2,476 Views)
Or use a simple FET (driving the FET will "connect" the drain and source).  We added a pull down on the gate just in case the DIO was disconnected for whatever reason.
GCentral
Message 3 of 8
(2,439 Views)
If you go with discrete implementation as suggested by crossrulz, do pay attention to the inversion in the logic, when DIO is high, the bus is pulled low and vice versa.
Santhosh
Message 4 of 8
(2,434 Views)
Well, in the case of I2C, a low on the bus is considered a "true" or a "1".
GCentral
Message 5 of 8
(2,428 Views)
Thank you both for the information. It's useful to know that push-pull is the default. I presume that if I used a tri-state buffer I would just wire both the enable and the input to the push-pull output?
I don't want to wait around to order special circuitry, so I asked around and someone found an old USB-6008 lying around in another lab so I will just use that I think. Let's just hope it still works.
Message 6 of 8
(2,425 Views)
Not really, it is still High is 1 and Low is 0, just that you don't actively drive the high but rather let the pull-up resistor do the trick.
Santhosh
Message 7 of 8
(2,414 Views)
If you use a tri-state buffer, you have to invert the enable signal as you want the buffer active when the DIO drives a LOW and tristate when HIGH.
High = Tristate
Low = Low
Santhosh
Message 8 of 8
(2,413 Views)
