I are planning to utilize PXIe-6535 to generate 10KHz pulse signal ( 100us width and 10us pulse width) for some specific application : this signal not only outputs PFI<0..5> , meanwhile can output same signal to PXI backplane PXI_TRIG<0..7> to trigger other instrument in the PXIE chassis. We have several questions on PXIe-6535 and don’t know how to do it.
- Can PXIE-6535 route same generated signals to any PXI_TRIG<0..7> bus on PXI backplane ? It seems OK according to NI PXIE 6535/6537 speciation: page 12).
- If the answer of question 1 is yes and can output the signal to PXI_TRIG<0...7> without phase delay, how to control PXIe-6535 device ( over nidaqmx interface) to make it happen? Further more
- Do you have sample code/snippets , such as: configure and output PXIe-6353 data pattern signal(s) to PFI and PXI_TRIG ( PXI backplane) pin(s) at the same time; real-time enable/disable this signal over the API etc.
Look forward to hearing from you soon.
Thank you
