08-08-2006 07:13 AM
08-09-2006
08:19 AM
- last edited on
02-16-2025
08:20 PM
by
Content Cleaner
You can use all 3 ports to perform static Digital I/O. Static DIO is basic digital IO that employs no handshaking or hardware-controlled timing. There is no clock associated with the functionality.
If you program involves any type of sample clock, then you are no longer performing static DIO, but correlated DIO. Correlated DIO enables digital and analog functions to be synchronized with hardware-timed precision. Basically, a clock is associated with the digital functionality. Port 0 of your M Series is the only DIO port available for correlated DIO.
If you need to clock your digital acquisition or generation on the 3 ports, then you need a High-Speed Digital I/O Device.
I hope this helps.
08-10-2006 07:29 AM
