Digital I/O
PCI 6516- setting P0.0 to high causes voltage drop on external power supply
I'm using a PCI 6516 for output of 24V. I have the positive lead of my power supply connected to pin 5 and the negative lead to pin 19. whenever i set port 0, line 0 (P0.0) to high, I get a voltage drop on the power supply to about 1.9V. There are no other wires so there is no short circuit anywhere. The rest of the lines work fine when I set them to high. The self-test runs fine, and I tried resetting the device several times. Could there be a potential damage to this specific port? Any solutions to this problems, or anything that may have caused this behaviour?
Ahmed
(5,402 Views)
Hi
From your post I can infer that you are trying to do a digital output so for example if you are using Port 6 as an output port, you must connect P6.VCC to the positive lead of an external power supply (5-30V DC) and P6.GND to the negative lead of the power supply. The output will then switch between 0V and the supplied voltage.
After looking at the manual I can see you have the correct connections. Yes, there is the possibility that the pin is damage, so let's go through some troubleshooting. Some questions I have for you are: what happens if you change the positive lead from pin 5 to 14, 28 or 27, do you get the same behavior?, How are you measuring the voltage, DMM, SCOPE? What do you read in other lines from port 0 when they are set to high? Can switch the lines from any other port to the correct Vcc but port 0?
Also I would like you to read this knowledge base and check if this is the behavior you are seeing, Expected Voltage Drop on the Digital Output Lines of NI-651x Devices.
Waiting for your reply
Jaime Hoffiz
Product Expert
(5,388 Views)
Sorry for the late reply. Here are the answers for troubleshooting:
-what happens if you change the positive lead from pin 5 to 14, 28 or 27, do you get the same behavior?
yes
-How are you measuring the voltage, DMM, SCOPE?
DMM
-What do you read in other lines from port 0 when they are set to high?
They all function as expected except for line 0. However, if line 0 is set to high, and all lines in port 0 are high, then all lines give a small voltage (about 0.4V) and pin 5 is around 1.85V
C
-yes, as long as port0 pin 0 is low. the change happens to the power supply, so all other ports are affected
thanks alot and appreciate your help
(5,363 Views)
Accepted by amamin
Unfortunately I’m going to say that this card is damage. Please get in touch with us so we can maybe trouble shoot it a little bit more. But most probably you will have to send the card for repair. Customer Service.
I’m sorry this was the result
Jaime Hoffiz
Product Expert
(5,346 Views)
