Digital I/O
PXI-6534
I’m using PXI-6534 and I’m trying to read and view from a digital channel. Can I use a digital graph or scope to view the signal as an oscilloscope? And which VI should I use to acquire the single?
(3,242 Views)
Hi aherna77,
The best place to start would be the LabVIEW example finder. Here you can find pre-made examples for exactly what you are trying to do.
In LabVIEW if you go to Help >> Find Examples... >> Hardware Input and Output >> DAQmx >> Digital Measurements >> Cont Read Dig Chan-Burst.vi
This example shows you how you can view the digital data from your card.
In LabVIEW if you go to Help >> Find Examples... >> Hardware Input and Output >> DAQmx >> Digital Measurements >> Read Dig Chan.vi
This example shows you how to acquire a single point
Please let me know if this helps and don't forget to check out the links below.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(3,228 Views)
