12-06-2023 12:56 AM
Hello
For a new project i need a softpanel for a PXI-6509 that runs in the background and is automatically updated when an in or output changes. In the foreground Teststand runs and the panel must popup when a key combination is pressed. Is there software available that does such a thing.
Kind regards
tonnie
Solved! Go to Solution.
12-06-2023 08:28 AM
This question is best to be posted on the NI TestStand board.
Control When the Front Panel of a SubVI Opens in LabVIEW on Keyboard Events is not difficult. But thing gets complicated when you want to run it from TestStand. You would need a termination monitor. See Asynchronously Starting and Stopping a VI in TestStand
12-07-2023 01:14 AM
Hello
Thanks for your replay.
I didn't mention it but we don't use Labview, we use C# in our test systems.
It seems that IPC (inter process control) can do the job. So i will have a look at that solution first
