Digital I/O
Suitable incremental encoder for NI USB-6216
i have a NI USB-6216 and i want to buy a rotary incremental encoder suitable for this card. i don't know the suitable encoder output signal as NPN,push- pull...ec. also the electrical connection which Compatible with USB-6216
best regrds
(3,713 Views)
Hi kukarobot,
The following articles will help assist you as you look into which encoder to purchase:
KnowledgeBase 3JAF2BVB: What is the Difference Between a Line Driver, Open Collector, and Push-Pull ...
KnowledgeBase 2WO9LA59: Can I Connect Both PNP and NPN Signals to a National Instruments DAQ Board?
Developer Zone Tutorial: Quadrature Encoder Measurements: How-To Guide
You will also want to be catious of the fact that counters on the USB-6216 will only accept signle ended measurements, so you will want to ensure that the encoder is not a differential encoder.
Ryan T
(3,691 Views)
