Digital I/O
USB 6501 analopg digital converter
Hello
I want to acquire an analog signal with my usb 6501. I may need to use an analog to digital converter. Can someone help me to choose one and give me some example of VI to do this please.
Thank you
(3,912 Views)
Your USB 6501 does not have any analog input channels, but I can suggest other USB devices. Like this one. But before you can make an informed decision- could you tell me what signals you wish to measure and the frequency at which they run at? The choice of Analog input device depends on this, and the one I linked to could only measure 8 channels at upto about 20khz.
If you wish to have Digital Outputs and Inputs and Analog Inputs and Outputs in one chassis, you may wish to consider cDAQ products and the C-series modules.
I hope this helps!
(3,908 Views)
