Digital I/O
USB6009 vs 6001
I have a doubt about these two hardwares.
If I change a 6001 for a 6009 in my program does it works? Do I need any new firmware or change in my program?
(4,911 Views)
Accepted by demarkIV
The 6009 uses the same DAQmx driver. Your existing code should work just fine (assuming digital I/O) as long as the device number has not changed and you aren't using more than 12 lines.
(4,890 Views)
OK Thank you Dennis
(4,886 Views)
They both use DAQmx as their driver.  You might have some setup/initialization to change to make sure your channels are pointing to the right device.  Other than that, you should not have any issues.
(4,883 Views)
