Digital I/O
Using PXI 6541 in real time applications
I want to use PXI 6541 in real time mood, can it be used in real time applications.
Message 1 of 9
(6,921 Views)
Yes
Message 2 of 9
(6,907 Views)
Thanks for reply,
Can you guide me how can I do it, I mean from where to start.
Khan
Message 3 of 9
(6,896 Views)
You would start by defining what you mean by real time. Are you talking about something like LabVIEW RT where run on a real time OS?
Message 4 of 9
(6,892 Views)
Message 5 of 9
(6,888 Views)
I am using PXI 6541 for data acquisition from an electronic card. Electronic card generates an interrupt signal and PXI acquire data. The interrupt signal is generated 1 KHz. But using my windows XP, I cant acquire data on this rate. The highest rate that I can acquire data is 50 Hz. If I want to acquire data with 1 K Hz, from electronic card using PXI 6541 and using Windows XP,  What Should I do.
Message 6 of 9
(6,839 Views)
You should be able to do so easily if you are using a hardware timed acquisition. You haven't mentioned what language you are using so that makes it impossible to provide an example.
Message 7 of 9
(6,828 Views)
I am using LabView 2009.
Message 8 of 9
(6,824 Views)
Then you should be aware of Help> Find Examples. Look under Hardware Input and Output>DAQmx.
Message 9 of 9
(6,819 Views)
