Digital I/O
Where can I find info on Digital Acquasition
Where can I find info regarding 6111E Digital Data Acquasition
Message 1 of 23
(5,251 Views)
Here are some links:
http://sine.ni.com/apps/we/nioc.vp?cid=11889〈=US
http://digital.ni.com/manuals.nsf/websearch/E55C2F21268C613486256997005343C9?OpenDocument&node=132100_US
The PCI-6111 board has the same digital capabilities as our E-series boards. Depending on what programming language you are using, there should be some digital IO shipping examples.
Another source for code examples is our DevExchange: http://zone.ni.com/zone/jsp/zone.jsp
-Sal
Message 2 of 23
(5,236 Views)
Hello Sal,
Thanks for your replay.
I need to acquire digital data form 3 lines :
Line 1: CLK -1 Mbps
Line 2: DATA - format = 1 sample = [16bit I][16bit Q][8 bit ACC][10 bit 0] = 20 ksamples/sec = 1 Mbps
Line 3: SYNC - 20 kbps
I have in my position PCI 6111E and PCI 6534 and Labview
I would like to use the CLK signal as trigger at down, and acuire the data first to data file
and after dynamicly to MATLAB.
1. Which PCI is more suitable for this task?
2. Can I activate Labview VI as server from MATLAB?
3. I just started with Labview and used "Buffered Pattern Input Digital Waveform" example, but i manage to acquire only 2 lines with
PCI 6534?
Thanks for your help.
Nir Corse
Message 3 of 23
(5,226 Views)
Hi Nir,
1) Since you are perfroming the high speed digital IO, I would suggest that you use the 6534 digital IO card.
2) I'm not sure about the VI server with Matlab. From what I've seen, people typically build their LabVIEW programs into C dlls that they can call from Matlab.
3) Depending on the version of LabVIEW that you are running, you should have some 6534 specific examples. I'm not exactly sure what the problem is. I would need a lot more information before I can comment on what is going on with that.
http://sine.ni.com/apps/we/nioc.vp?cid=13505〈=US
Message 4 of 23
(5,204 Views)
Hi Sal,
Thank's for your replay.
I have decided to use PCI 6534 and BNC-2110 of NI.
I am also using LABVIEW example program "Buffered_Pattern_Input_Digital_WaveForm_Graph_653X.vi" as first try.
(I also added "File.." component to save the acquired signals.)
I can see all 3 digital lines data when they are connected to port 0, DIO0~7 lines, and program configured to internal clock.
I would like to use my clk line as trigger to the other 2 lines.
I connected clk line to PFI0/TRIG1 PIN, and set the program to external but didn't see any response.
1. Is that possible connection?
2. How can I acquire the data and sync lines by using clk as trigger (falling Edge) in the following configuration?
Best Regards,
Nir Corse
Message 5 of 23
(5,196 Views)
Hi Nir,
I'm not exactly sure what you are trying to do. Could you send me the modified VI that you are currently using and I can take a look at it. Also, maybe more description of what you are trying to do.
You have a clock signal on line 1 and you what lines 2 & 3 to be triggered on the clock. This means that you want to latch the data on lines 2 and 3 on the rising edge of the clock signal on line 1, correct?
-Sal
Message 6 of 23
(5,172 Views)
Hi Sal,
I would like to use my CLK line as external trigger to the 2 other lines, (Data,SYNC).
I would like to configure the trigger to falling edge.
I would also like to read/save the triggered Data and SYNC information to a file.
At the current state I manage to see all 3 lines on the graph display, but i can not read them to a file properly.
When i open the file i get values like 32, 64 ... and not "0" / "1".
Best Regards,
Nir Corse
Message 7 of 23
(5,151 Views)
It would be helpful if you could post your code. If it is at all possible, please do so.
-Sal
Message 8 of 23
(5,131 Views)
I added my code.
I would like to note that when I save DATA and SYNC lines to a file i can't view them as "0" and "1".
Best Regards,
Nir
Message 9 of 23
(5,124 Views)
Hi Nir,
Your code is saving the data to a file in the unsigned 8 bit integer datatype. You digital read is returning a integer interpretation of an 8 bit binary number. For example, if your digital pattern was 0000 1001 it would be saved as 2^4 + 2^1 = 17, so your file would have an "8" saved. So from your integers you should be able to know what the digital pattern was. If your file has the intergar value 64 saved, it would correspond to 0010 0000.
-Sal
Message 10 of 23
(5,115 Views)
