Digital I/O
board for high-speed asynchronous serial LVDS
We currently are using a PXI-6561 digital waveform generator.
We are only using two of the lines out of the 16 - one for serial out and one for serial in
The communication is asynchronus.
Is the PXI-6561 the best board for this or is there a better option for us?
20MHz clock is our requirement.
It seems such an overkill to use PXI-6561.
(4,561 Views)
Hello nyc,
Given some of the constraints it seems that is the best choice for your setup.  Being at 20 MHz, you've already gone past the multifunction DAQ digital I/O family.  None of these however include LVDS logic family.  Those two put you in to the HSDIO category, where there are two choices: the 6561 or 6562 in either PXI or PCI.
Your setup is a little over-spec'd which is fine, is there something you were particularly worried about?
Anthony F.
Staff Software Engineer
(4,545 Views)
Hello nyc,
As a follow up there are a few more devices that are directly compatible with LVDS such as the 6583, 6585 and 6587 adapter modules which would be used with an FPGA module such as the PXI-7951R
It is also possible to use our 655X line of Digital Stimulus/Response devices to interface with an LVDS signal.  We have a Developer Zone Tutorial that describes how to use the 655X devices here.
Anthony F.
(4,529 Views)
Thank you.
It does look like we have the "best" board for our needs.
(4,499 Views)
