Digital I/O
can't select channel in an executable daq i/o control properties
I dont know what is different about this program, since I have built many executables and deployments packages (installers) using the same "tecniques". I just gave up on this one, since I tried everything that I knew and have read in the forums.  Its mostly curiosity now as to why the I/O ports do not appear when I create the .exe.
Message 11 of 12
(1,071 Views)
This is a strange issue. All I can think of at this point is that perhaps the vi is corrupted. Have you tried copying and pasting the code of the vi in question into a brand new, blank vi? This typically fixes any corruption.
Hope this helps!
Margaret Barrett
Digital Multimeters and LCR Meters
Message 12 of 12
(1,061 Views)
