09-11-2013 01:41 AM
I would like to generate digital pulses at 5khz oe less rate, any hardware recommendation? preferable usb and budget type.
I do have usb 6501, i try work on it, maximum output is 1khz the best. Is it possible to further up ?
Appreciate any help here.
regards,
Simon
Solved! Go to Solution.
09-11-2013 03:07 AM
Anything in http://sine.ni.com/np/app/main/p/bot/no/ap/daq/lang/en/pg/1/ps/30/sn/n17:daq,n21:41,n24:USB,n6:7693/ other than 6000,6008,6009 would work fine.
09-11-2013 03:51 AM
Hi kate,
If i go for NI USB6210, is it all the I/O can be use to generate 5khz pulses train?
regards,
09-11-2013 03:55 AM
Only two counter channels are available for such tasks.
09-11-2013 11:03 PM - edited 09-11-2013 11:10 PM
Hi KateB,
Can i simultaneous use these 2 counter channel to generate different freq of pulse train let say 5Khz and 1khz?
My project is to generate pulse train at the same time monitor one of the IO, when receive high, i will going to stop the pulse train generation.
I have go through the example of daqmx for usb6210.
My question is when i stop and clear the task, does it mean that the pulse train generation will stop immediately or still need to wait all the pulse train completely output??
Attach with the vi.
regards,
09-11-2013 11:07 PM
You can use each channel to generate pulse train at different frequency simultaneously, and pulse generation will immediately stop once the task is stopped.
09-12-2013 01:17 AM
Hi KateB,
i check the datasheet, it mentioned below:
as i need more than 4 digital output, can i change those 16 analog inputs become digital output OR 4 digital inputs become output?
regards
09-12-2013 01:24 AM
No, you need to consider a model with more digital outputs. Another thing is that DIO shares signal line with counter. If you don't clearly state how many DIOs, and pulse generator you need, you may choose a wrong model.
09-12-2013 01:29 AM
I need 2pulses generator and more than 4 digital ouput.
can explain more on this.
Do you mean that the IO will be used out for the 2 counters?
09-12-2013 01:40 AM
There is ni 6008 / 6009, it do provide pulses train, right? but only 1 counters and more digital IO
regards
