Digital I/O
is it possible to use PCI-6519 with traditional NI-DAQ 7.4
I´ve got an application wich is written for PCI-OPDIO16 with the traditional NI-DAQ driver. Now I use PCI-6519 instead PCI-OPDIO16.
In Measurement&Automation the PCI-6519 is only shown in NI-DAQmx-Devices and not in traditional NI-DAQ-Devices.
The error-message from the compiler is "function Init_DA_Brds (return value == -10005)".
Is there a possibility to use the traditional NI-DAQ-Treiber with the PCI-6519? So that I don´t have to change the software.
thank you
(3,256 Views)
No, according to this info it is only DAQmx 7.4 compatible (7.1 if under Win98/Me)
http://www.ni.com/support/daq/versions_pci_pxi.htm
(3,253 Views)
