Home
Community
Discussion Forums
Additional NI Product Boards
Digital Multimeters (DMMs) and Precision DC Sources
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Difference between Reference and Start in Triggering ?
Shaft DAQ
Member
03-03-2008
03:43 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi
Can anyone explain What is the difference between the Reference and Start when Triggering ? and when should you use them?
Any commets will be very much appreciated..
Many Thanks in Advance
Mohamad
0
Kudos
Message
1
of 3
(7,786 Views)
Reply
Re: Difference between Reference and Start in Triggering ?
K_Bull
Active Participant
03-07-2008
05:53 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Start trigger is the trigger signal used for post-triggered acquisition. The hardware starts the A/D conversions after the trigger is received.
Reference trigger is the trigger signal used for pre-triggered acquisition. The hardware starts acquiring data before the trigger signal is received.
For more information about this, please read the
Tips and Techniques in DAQ triggering with NI-DAQmx
If you are using a DSA card, also read
Trigger Condisions for Analog Start and Reference Triggers in the Same Channel for DSA Cards
K_Bull
orbimation.com
0
Kudos
Message
2
of 3
(7,771 Views)
Reply
Shaft DAQ
Member
Author
03-07-2008
06:49 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Many Thanks Kabul...
Mohamad
0
Kudos
Message
3
of 3
(7,769 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
