Digital Multimeters (DMMs) and Precision DC Sources
Trouble using NI USB-4065 with VMWare virtual machine
I'm going to work with a virtual machine (windows xp) and I need to use a DMM NI USB-4065.
When I connect the USB-4065 to the PC, the virtual windows xp recognize the new HW and also MAX display the new device on the DAQmx list.
It appears ok but if i try to use the USB-4065 (opening the soft frontpanel or in a LabView VI), the device doesn't work.
If I use the soft frontpanel, when i click one botton, the panel seems work but doesn't measure anything; if I try to restart the softpanel, it doesn't work and "freeze" the panel's display.
If I use LabView, the VI return an error about maximum time of the mesurement.
I try to use the device on the real machine (not with VMware) and the USB-4065 works, whith soft panel and whith VI.
I upgrade the DMM's driver on the virtual machine, bat the device doesn't work again.
... I haven't others idea, someone can help me with this trouble?
Thank's, Sem.
Message 1 of 9
(11,954 Views)
- which kind of error do you receive (error code)?
- which version of windows xp service pack do you use?
Thanks for your reply.
Giuseppe.
Message 2 of 9
(11,946 Views)
thankyou Giuseppe.
I use VMware; the virtual machine is windows xp 32 bit SP3.
I repeat the trouble with Soft front panel and with LabView2009, and I attach relative images.
The only news is that I see the DMM works only the first time I read; if i try to change measure (whit Soft front panel) or if I re-run the VI in LabView, the DMM stopp to work.
Thankyou, by Sem.
Message 3 of 9
(11,943 Views)
NI-DMM is not supported in virtualized environments.  There's a lot of hardware abstraction that virtual machines can't handle.  If you're using  an Intel Mac, Boot Camp is the only supported method (since it's not virtualized).
-John Sullivan
Problem Solver
Message 4 of 9
(11,933 Views)
Accepted by IronSem
Hi John,
this isn't a good news for my project but tankyou for information.
See you, by Sem.
Message 5 of 9
(11,923 Views)
Dear all,
I have installed NI-DAQmx and NI DMM 14.0 drivers.
Windows 7 (64bit) recognizes the unit in device manager but Meausrement & Automation explorer does not.
What can I do?
Thank you,
Tomaz
Message 6 of 9
(9,908 Views)
Tomaz, you need to give more information.
Are you using VMWare?
What version?
On what platform?
On what hardware?
Marcos Kirsch
Chief Software Engineer
NI Driver Software
Message 7 of 9
(9,904 Views)
two years ago, I had to sobstitute the NI DMM with another commercial DMM (I usec TekTronix), because of NI DMM can't be virtualized; last summer, I test the NI VirtualBench and now I'm thinking to replace my commercial instrument whith this.
VB is smart, small, easy to use, cheap and virtualized... I think that VB is one of the best USB HW Test invented until now, and the performance are sufficient for the most of standard measures. I suggest to use VB.
Message 8 of 9
(9,893 Views)
Hi, thank you for the answer.
I have reinstalled the NI DMM 14 drivers. Now I can see something in the automation Explorer, but cannot start test panel software.
Please see picture for details.
Message 9 of 9
(9,888 Views)
