cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
CVI Local 'X' has not been initialized.
#include <winsock2.h>
#include <ws2tcpip.h>
#include <iphlpapi.h>
#include <stdio.h>
#define MALLOC(x) HeapAlloc(GetProcessHeap(), 0, (x))
#define FREE(x) HeapFree(GetProcessHeap(), 0, (x))
int  main()
    int i;
    // Variables used by GetIpAddrTable
    PMIB_IPADDRTABLE pIPAddrTable;
    DWORD dwSize = 0;
    DWORD dwRetVal = 0;
    IN_ADDR IPAddr;
    // Variables used to return error message
    LPVOID lpMsgBuf;
    // Before calling AddIPAddress we use GetIpAddrTable to get
    // an adapter to which we can add the IP.
    pIPAddrTable = (MIB_IPADDRTABLE *) MALLOC(sizeof (MIB_IPADDRTABLE));
    if (pIPAddrTable)
        // Make an initial call to GetIpAddrTable to get the
        // necessary size into the dwSize variable
        if (GetIpAddrTable(pIPAddrTable, &dwSize, 0) == ERROR_INSUFFICIENT_BUFFER)
            printf("Not enough space, re-allocate...\n");
            FREE(pIPAddrTable);
            pIPAddrTable = (MIB_IPADDRTABLE *) MALLOC(dwSize);
            if (pIPAddrTable == NULL)
                 printf("Memory re-allocation failed for GetIpAddrTable()\n");
                 exit(1);
            else
                 printf("Memory re-allocation for GetIpAddrTable() is OK!\n");
         else
              printf("Buffer is sufficient...\n");
    // Make a second call to GetIpAddrTable to get the actual data we want
    if ( (dwRetVal = GetIpAddrTable( pIPAddrTable, &dwSize, 0 )) != NO_ERROR )
        printf("GetIpAddrTable() failed with error %d\n", dwRetVal);
        if (FormatMessage(FORMAT_MESSAGE_ALLOCATE_BUFFER | FORMAT_MESSAGE_FROM_SYSTEM |
                FORMAT_MESSAGE_IGNORE_INSERTS, NULL, dwRetVal,
                    MAKELANGID(LANG_NEUTRAL, SUBLANG_DEFAULT),       // Default language
                          (LPTSTR) & lpMsgBuf, 0, NULL))
            printf("\tError: %s", lpMsgBuf);
            LocalFree(lpMsgBuf);
        exit(1);
    else
         printf("GetIpAddrTable() should be fine!\n");
    printf("\n\tNumber of entries: %ld\n", pIPAddrTable->dwNumEntries);
    for (i=0; i < (int) pIPAddrTable->dwNumEntries; i++)
        printf("\n\tInterface Index[%d]:\t%ld\n", i, pIPAddrTable->table[i].dwIndex);
        IPAddr.S_un.S_addr = (u_long) pIPAddrTable->table[i].dwAddr;
        printf("\tIP Address[%d]:     \t%s\n", i, inet_ntoa(IPAddr) );
        IPAddr.S_un.S_addr = (u_long) pIPAddrTable->table[i].dwMask;
        printf("\tSubnet Mask[%d]:    \t%s\n", i, inet_ntoa(IPAddr) );
        IPAddr.S_un.S_addr = (u_long) pIPAddrTable->table[i].dwBCastAddr;
        printf("\tBroadCast[%d]:      \t%s (%ld%)\n", i, inet_ntoa(IPAddr), pIPAddrTable->table[i].dwBCastAddr);
        printf("\tReassembly size[%d]:\t%ld\n", i, pIPAddrTable->table[i].dwReasmSize);
        printf("\tType and State[%d]:", i);
        if (pIPAddrTable->table[i].wType & MIB_IPADDR_PRIMARY)
            printf("\tPrimary IP Address");
        if (pIPAddrTable->table[i].wType & MIB_IPADDR_DYNAMIC)
            printf("\tDynamic IP Address");
        if (pIPAddrTable->table[i].wType & MIB_IPADDR_DISCONNECTED)
            printf("\tAddress is on disconnected interface");
        if (pIPAddrTable->table[i].wType & MIB_IPADDR_DELETED)
            printf("\tAddress is being deleted");
        if (pIPAddrTable->table[i].wType & MIB_IPADDR_TRANSIENT)
            printf("\tTransient address");
        printf("\n");
    // Clean up/reset
    if (pIPAddrTable)
        FREE(pIPAddrTable);
        pIPAddrTable = NULL;
    return 0;
Hola
Tengo un problema al tratar de compliar este codigo, el compliador me arroja este error
" Warning: Local 'IPAddr' has not been initialized".
He compliado este codigo con otros paquetes y no he tenido ningun problema.
Tengo agregadas las librerias #include <winsock2.h> y #include <iphlpapi.h> a mi proyecto de CVI.
Gracias
0 kudos
Mensaje 1 de 2
2.975 Vistas
Hola Antonio;
El problema que encontré con el código es que la variable local IPAddr está definida con un tipo in_addr es decir una dirección de Internet IPv4 que a su vez es una structura con varios caracetéres. Estas esctructuras están definidas únicamente en el Windows SDK de Windows Vista y posterior, por lo que si estás trabajando con un sistema operativo previo es posible que no encuentre esta definición en el header que incluyes.
Lo que te recomendaría sería agregar la definición de la estructura en el inicio del programa y probar desde ahí;
La definición que encontré en el sitio de Microsoft sería algo así:
typedef struct in_addr {
union {
struct {
u_char s_b1,s_b2,s_b3,s_b4;
} S_un_b;
struct {
u_short s_w1,s_w2;
} S_un_w;
u_long S_addr;
} S_un;
} IN_ADDR, *PIN_ADDR, FAR *LPIN_ADDR;
El mínimo cliente soportado es Windows 2000 Professional y el servidor Windows 2000 Server
Si estás trabajando con una versión Win 2000, 2003 server, XP  entonces deberías agregar la librería Inaddr.h y Winsock2.h
Espero esta información te sea de utilidad
Éxito!!!
Marisol
0 kudos
Mensaje 2 de 2
2.917 Vistas
