cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Error -61488 cRio 9004
¡Resuelto!
Ir a solución
I was compiling the FPGA cRio 9004 but my PC restarted during the compilation, after that an error showed up (-61488). It says that I need to comunicate with the NI support, please tell me what I need to do.
0 kudos
Mensaje 1 de 3
4.570 Vistas
Solución
Aceptado por el autor del tema alexortiz
Hi Alex;
You should try out the solution in the following KB
Error -61488 after a LV FPGA Code Comilation Failure
If it doesn't work I would recommend formatting the cRIO in MAX (right click format disc) and reinstalling software
Good luck
Mensaje 2 de 3
4.559 Vistas
Thanks, only I needed to create a new project for the solution.
0 kudos
Mensaje 3 de 3
4.543 Vistas
