Discusiones sobre Productos NI
cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
I Can't display TESTSTAND HTML results with TSGRAPH in PC without TESTSTAND.
¡Resuelto!
Ir a solución
I Can't display TESTSTAND HTML results with TSGRAPH  in PC without TESTSTAND installed. We locate in the same folder the HTML file and the TSGRAPH.ctl file. The internet explorer display the following error:
The object doesn't accept the attribute or method "TSGRAPH1.PlotY
0 kudos
Mensaje 1 de 6
4.031 Vistas
Hi
Are you sure to be writing the parameters correctly ?, I see in the error that you have quotes in the method, and you should not see it. Maybe you have double quotes and thats the error that is appearing.  -->>"<<-- TSGRAPH1.PlotY. it is invalid and TestStand doesnt accept it. Do you see the method PlotY in the parameters area when you write TSGRAPH1 and press the '.' key? That means that it is detected and that you can use that method.
Regards
Jaime Peña
National Instruments Mexico
Ingeniería de Aplicaciones
www.ni.com/soporte
0 kudos
Mensaje 2 de 6
4.023 Vistas
Thank you for your quick answer. The call to TSGRAPH is working properly in PC's with TESTSTAND installed but when I try to open the HTML in other PC without TESTSTAND we can see the results except graphs and a warning error is reported by the explorer in the line written bellow. I suspect that we need to install in the OS registry some handler to the .tcl file.
<TR><TD BGCOLOR=#ffffff valign="top"><FONT SIZE=-1>APU_MASTER_SW_ON[1..66]:<TD BGCOLOR=#32ffff WIDTH = 37% valign="top"><FONT SIZE=-1><OBJECT classid="clsid:BA578A47-350E-4115-811B-C80DB80EBD33" height=150 id=TSGRAPH1 style="LEFT: 0px; TOP: 0px" width=100%> </OBJECT><SCRIPT DEFER LANGUAGE="VBScript">
Call TSGRAPH1.PlotY(Array(0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000, 1.000000), 0, 1)
</SCRIPT><TR><TD COLSPAN = 2>
Thank you
0 kudos
Mensaje 3 de 6
4.019 Vistas
Hi
You need ActiveX and some components to display graphs in HTML files. Here is the link where you can download it.
Displaying a Graph in a TestStand HTML Report Without TestStand Installed
http://digital.ni.com/public.nsf/allkb/7AE2EB304D4F9D4F86256B8100795B83?OpenDocument
Regards
Jaime Peña
www.ni.com/soporte
0 kudos
Mensaje 4 de 6
4.014 Vistas
Solución
Aceptado por castellano
Thank you, the problem is already resolved.
0 kudos
Mensaje 5 de 6
4.000 Vistas
Oh so sad, this link already removed.
@james88 wrote:
Hi
Regards
please set this as ANSWER or KUDO this post, if it help you.
0 kudos
Mensaje 6 de 6
755 Vistas
